not showing up in who
Nov 2013
Pa
264
Just got a new laptop and installed rslinx with a PCMK card series a. Drivers loaded Ok Status Running with no errors.
Hooked up cable to SLC and DH485 light comes on, but SLC is not showing up in WHO but my terminal does. Tried 3 SLCs no change. Running windows 7 pro
Any help?
Yes it is a old PCMK, waiting for UIC cable
I am running W7-64 and have a series B PMCK card and at first it would not show up in RSLinx unless it was connected to a network, now it stays in RSLinx (I am running version 3.60)
Alan
I have found quite often when changing from one SLC to another I have to go into the CONFIGURE DRIVERS option & auto-configure it to get it set to the correct baud for the CPU connected to.
Are you connected direct serial or using a usb adapter? A lot of new laptops don't use serial ports anymore (mine). I had an adapter that worked well with windows XP but not 7. If this is your case buy a high quality adapter, I use a tripp-lite model: usa-19hs. it needs to be high speed.
Good morning, We've had an issue with a couple of servo valves and was wondering if anyone had seen anything similar. After a drop in pressure...
121
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
410
Hello. I am working in FTVSE v8. I have many trends set up some of them work others do not. The ones that don't work show the foot print of the...
247
Hello everyone, I am working in a platform and we installed FTV CLIENT SE V 12 IN ALL THE CLIENTS COMPUTERS, we have 6 clients and only 1 is not...
111
Searching edit zones within all routines and other criteria still says no results found, yet I still have the "edits present" indicator at the...
259
