NT drivers for HP Compaq NC6000 laptop
Maia
Sep 2004
Laguna
29
This is a bit off the PLC topic but still related. I downgraded my HP compaq NC6000 laptop from Windows XP to Windows NT 4.0. Siemens PCS7 V5.1 can only be installed in Win NT. The problem is, HP COMPAQ does not have drivers (video card, network card, audio) for this laptop model running in NT. I would really appreciate if you can help me find these drivers. Perhaps you know websites sharing these stuff.
Thanks,
maia
Ouch... NT is long non-supported. Not many hardware manufacturers write drivers for old OS's, and the driver structure is vastly different between Windows NT 4.0 and Windows 2k, not to mention XP.
That being said, depending on the type of integrated hardware, you might be able to find NT compatible video drivers at www.guru3d.com for nVIDIA and ATI, maybe some others, or www.intel.com for the Intel graphics chipsets.
For network cards, try some of the generic ones, such as any Realtek combo driver, or 3Com, unless you know the NIC manufacturer.
Laptop audio is likely to be a challange, but some older drivers for either Soundblaster or TurtleBeach MAY work. Many of the laptop audio systems are based on Connexant (Rockwell, but not AB Rockwell) or ESS systems. You might look here http://drivers.soft32.com/index-2-12-111-0-4.html for a bunch of assorted drivers.
Good luck.
Hi currently my existing PLC using AB motor & driver to spin production, however customer want to another set, if this possible we use different...
248
I have several older systems in our plant that use the 1756-ENET card for comms, and we have some with the 1756-ENBT cards as well as one system...
942
Have tried to get the tag details from the PLC through python pycomm module.But getting Tag doesn't exist error. Am using pycomm version = 0.11.0...
517
Hello Experts Last time I tried to connect with the PLC GE Fanuc 90-30 using the cable obtained from PLCCable I was unable to connect because...
1,248
Long shot, anyone got the Pilz PDIA 2 Step 7 drivers zip file they could send me?
1,192
