NT20S-ST121-EV3 / C200HG CPU43 error
iandb
Feb 2016
Berkshire
Hi all
Hoping some one can help and point me in the right direction.
I have a customer with the above combination. It was returned to us here in the UK along with the CPU. We programmed the screen with it's original file and all tested Ok here with the CPU.
It is now back with customer in USA and they are getting an error as follows:
Setting Error
Screen No.: 0067
In our programme screen 0067 is an E-stop alarm for the machinery (in this case a printing press)
Have found the below. As I am not a programmer am a bit stuck. Assuming that one unit is looking for an E-stop in the other unit which doesn't exist, hence the error???
Message
Setting Error
Cause
Bits or words allocated to the PC
memory cannot be found in the
screen data
RemedyCheck the memory area in the PC used and correct
the bit and word allocations in the screen data.
Hi, is the Omron nt20s-st121-v1 hmi can be programmed with a tool on CX-Programmer package? If not wich software is needed to perform on it? Thanks
3,503
I have a machine with an Omron Sysmac CQM1 PLC & NT20S HMI. I got the NT software installed on a VM & the OEM files, it opens OK. I also have...
2,452
Good day to every body I am trying to replace old touché screen [omron nt20s-st121-v1] To new one [[omron nt20s-st121b-v3] they look identical and...
1,987
I have two of the same units that are using a CPM1A and an NT20S-ST121B-EV3. I am not able to connect to the touch screen as far as i can tell via...
4,002
Hi, I'm learning to program my plc with hmi nt20s ,do someone has a program example? many thanks, JuGa
1,369
