Number of total tags - RSLogix 5000
rankhornjp
Dec 2008
Georgia
241
Is there a way to count the number of tags (including dot fields) in RSLogix 5000 automatically?
When I export the tag database and open it in Excel, it only shows the main tag, but not the dot fields. (e.g I have a Motor AOI, the exported file will show Motor1, but won't show Motor1.start, Motor1.stop, Motor1.running, etc.)
I've tried to copy/paste the tags into Excel, but the program (Logix) locks up.
When you export as *.L5K, each sub-element of each defined Tag is on a new line, so you can count the number of lines in the TAG section.
Why do you want to know ? I'm curious about how the number of sub-elements would be useful information.
Trying to get a total count for a new Historian. Customer isn't sure what all they want, so I'm trying to figure out worse case for them.
That makes great sense, thanks for the feedback !
I know that some HMI and historian systems can be clumsily configured to literally read every tag in the controller, slowing the system to a crawl.
I just had to convince a customer that their specification requirement that "every input" be timestamped and recorded in an SQL database was unwise.
Comments of a Tag will not export without a description.
Example> The Comments of MY_DINT only show Bits 0, 2 and 4. I did not Comment on Bit 1, 3, 5 or 6-31. Therefore they are not exported to the CSV file.
In a system I'm working on, remote well pump sites report to a central controller. Amongst other signals, the remote well pumps report the daily...
4,751
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
121
Complete noob here, using a Click C0-02DD1-D to run a test stand. Requirement is to turn on motor run for X seconds, turn off and dwell for X...
1,089
Hi, I have this weird issue whenever I try to change the SNN from a Point IO Im missing the three ... dots to open the pop up and change it...
619
I'm doing my first PanelView 5000 application with Logix View Designer v8, and am of course jumping in headfirst. One thing I don't find is a way...
704
