odd or even
VJTX
Oct 2007
TEXAS
126
I would like to determine if a counter setpoint is odd or even. This is on a micrologix 1100 plc. Is the best way to do a div/2?
If least significant bit is 1 then it is odd, else it is even.
e.g. assuming T4:0
If T4:0.PRE/0 is "1" then is odd
[Edit - OK, timer/counter - same idea. You want I should actually read the posting carefully?]
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
102
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
453
I have been requested to test this proportioning valve for PLC control of flow/pressure. Dwyer Series SVP Proportioning Solenoid Valve The flow...
439
Howdy guys - Looking for some insight on the MAM instruction. Had an interesting one today: I performed a controller upgrade on an older system...
452
Hi everyone, curious if anyone has ever witnessed the following comm error: A little history, I had a department PC die, WIN 7. Had to upgrade...
644
