starctyman06
Hello everyone ! I am a old dog trying new tricks ! I am currently working on a Oil Boiler Control project AB SLC 1000 system that I could use some friendly help with. I need to implement a program that consist of timing, latching and interlocking the operation of an Oil Burner Control to a safety shutdown. Here is the deal. I need to create a program that shall consist of a burner that will turn on when heat is called for by a heating thermostat with Normally Open contacts (the contacts close to call for heat). When the burner is started a safety device (light detector) will check for presence of a flame. If the safety detector "sees" fire it will close a set of contacts indicating everything is okay and the burner will continue to run until the thermostat is satisfied. However, if no flame is detected within 10 seconds of starting, the burner is shut down and prevented from re-starting until a RESET switch is pressed. A safety shutdown of the burner should turn on a reset lamp that indicates a malfunction so someone will know to press RESET. Any help would be appreciated. BTW, sarcasm (I did this in HS) BS is not needed. Thanks !
