oil pipeline control system
Charbel
Jan 2012
Beirut
307
Dear,
What are the sensors / devices that are usually lcoated on oil pipeline getting oil from one place to another over long distance say around 100KM.
i guess there will be a metering skid at the receiving end. Do they need any ESD buttons on the line for closing valves in case of leakage?
thank you for your feedback :)
Charbel
typically they monitor pressure at any point that they can and they also monitor the amount of oil going out at each station and then the amount coming in at the gathering facility. using those values they can detect leakage.
Having been an engineer on the TransCanada XL Pipeline these are some of the devices found on the pipeline as well as the metering skids, tanks, customer terminals:
1.0 ESD first and foremost!
2.0 Pressure
3.0 Flow
4.0 Leak Detectors
5.0 Temperature (When needed)
6.0 Flame detectors.
7.0 Fire water systems
These are but a few.
It should be mentioned that most if not all of the above interact with the ESD in case of a system problem.
Hope it helps.
I may have some drawings that I could look at and perhaps get a more accurate list.
Malt
Hello to all, is my first post on the forum, I searched everywhere, but I could not find an answer to this problem; I am quite experienced in...
989
So I'm having issues with a certain rung and one of my coworkers mentioned it may not allow the signal past the latch coil. For example in the...
27
3,757
I need help with vijeo citect 7.4 as I use Modbus TCPIP to get the data, it turns out the address is having error.. For example, when I write...
890
I thought of this before and always did like everyone else and put 2 relays next to each other and wire the contacts parallel, but... Has anyone...
1,183
Hi, I have never used modbus communication in Codesys 2.3, any tips and tricks are much appreciated. The system is a Wago 750-881 that controls...
1,856
