Old School IDEC Controller software needed.
bobwithdana
Dec 2003
california
239
We have a process system controlled by an IDEC FA-3S controller and cant find the software to get the program. We have the windows 95 laptop and cabel we use to use for it but no software.
Can someone point me in the right direction.
Bob
Is it called IDEC isumi?
I have a copy with cable and software that I would be willing to part with for REALLY cheap.
It is the DOS version, used for programming all of the Mitsubishi PLC/s.
It MAY be written in "cubiq". Try searching your laptop for a program or file that contains that name. It runs in DOS or the simulated DOS that is part of windows.
Stationmaster
I've got an old WinCC project and I'm trying to check what tag address certain values relate to. I have a screen that refers to...
2,219
Hello All, So i ran across the TI505 PLC from Texas instruments, which is under Siemens now. This is a very old PLC, and as simple as it may...
3,746
You know who you are... ;) My customer has an old cartoner run by an Omron S6 (3G2S6-CPU15), with two ID-411 input modules, and two OC-221 output...
2,456
I want to connect three PLCs together. I have two SLC 5/03s. One with an available serial port, and one with an available DH485 port. And one...
4,078
On the old school SLC 500 brick...the port on the front that looks like an RJ45 port, is that a DH-485 port like what I would find on a SLC 5/03...
3,186
