'Old School' Omron Guys...
Eric Nelson
Apr 2002
Randolph, NJ
4,346
You know who you are... ;)
My customer has an old cartoner run by an Omron S6 (3G2S6-CPU15), with two ID-411 input modules, and two OC-221 output modules. Still working!... (y)
These are the PLCs I started with, and I know I still have my PRO16 programming console around somewhere, but haven't found it yet... :(
I did find some other fun stuff though: A PRO15 and PRO27 console, and even an S3D-P (and manual!) for the little S3 PLCs... :ROFLMAO:
Anyway, the customer wants to 'upgrade' the machine to a CLX (I will convince them a ML is sufficient), so I would love to get the existing program out of the ol' S6.
I haven't finished digging, but in the event I don't find my programming console, I just wanted to see if anyone here still has one I could borrow. I would cover shipping. There are a few on eBay, but I can't justify buying one for this single job.
-Eric
Here, here! But in Ozz. No gear for them these days though.
I find that hard to believe - a testament to how tough the old ones were?
With relay outputs, no less! The machine looks 'well-used', but I don't know how many actual cycles are on it. My customer is a used equipment dealer, and they had this one in storage. Dusted it off, plugged it in, and it works. Relays might not be original. I'll dissect it after the conversion. I remember that the entire guts can be easily removed from the front, but I don't remember if the S6s had plug-in relays like the C-Series.
Still haven't found my handheld, but I know it's around here somewhere... :unsure:
-Eric
.... a testament to how tough the old ones were?
I realize the PLC-5 isn't by any means THAT ancient however, I have one that has been running a CVD operation for over 22 years and it gives me less trouble than any of the newer ones. What I can't show is the layers of powder that have accumulated on the chassis over the years and the darned thing still doesn't skip a beat.
Just to follow up, PLCs.net member bluebyu was kind enough to loan me his PRO16 console... :site:
I successfully documented the program today, so I'm all set... (y)
Attached is a quick picture of the PLC (yes, in RUN mode!). Sadly, it will soon be replaced by a ML1400. I wonder if the ML will survive as long as this ol' S6 did?
-Eric
I've got an old WinCC project and I'm trying to check what tag address certain values relate to. I have a screen that refers to...
2,219
Hello All, So i ran across the TI505 PLC from Texas instruments, which is under Siemens now. This is a very old PLC, and as simple as it may...
3,746
I want to connect three PLCs together. I have two SLC 5/03s. One with an available serial port, and one with an available DH485 port. And one...
4,078
On the old school SLC 500 brick...the port on the front that looks like an RJ45 port, is that a DH-485 port like what I would find on a SLC 5/03...
3,186
We have a process system controlled by an IDEC FA-3S controller and cant find the software to get the program. We have the windows 95 laptop and...
3,439
