I have just "finished" a modification to a conveyor system.
This system had inadequecies in product flow and/or accumulation.
I was using Omrom CX Programmer.The original program was a Syswin V3.34, which I had backed up previously.
The newer that I was working with is a XXXX.cxt file
The conveyors had been running for hours whilst I edited.
I left the area then the operator called and said the conveyors could not be restarted.
Found that the CPU had gone into "Program" mode???
The processor had faulted due to "Duplcate outputs" and had listed all the Set/Reset instructions except for the ones I had added.
The CPU would not accept and go into run mode, whatso ever.
Tried the latest backup file which also was a .cxt file and same result. Loaded the second latest backup file (.cxt)and success.
Lost all my work in doing so.
Was this due to a XXXX.cxt file as this would not be a true converted file as Syswin V3.34 could be used to go online(A "true" CX- Programmer program uses .cxp files)??
Has anyone seen this problem and how can it be rectified??
And any other thoughts on this would be appreciated...
Bewildered and unhappy
