Omron C200HS to Kepserver
Nov 2019
UK
Hi folks
Looking to connect an Omron C200HS to Kepserver using the Peripheral port and the CQM1-CIF02 programming lead. I want to try and use host link protocol on the Peripheral port as I wont need to add new hardware and stop the line.
I have experience connecting Elau, Moeller and Siemens to Kepserver but this is my first Omron.
Does anyone know if its possible to make a CQM1-CIF02 lead. They are now selling for over 1000 pounds a pop and I have 10 machines to connect.
Any advice greatly appreciated.
It's been some time since I have used the C200HS I believe the programming port is 232, this poses a number of problems, 232 is short distance and not multidrop. I suggest you use ethernet to 232 converters this way you can multidrop them and use the Kepserver ethernet encapsulation i.e. each Ethernet/232 connection will have it's own IP address.
I have not used this on C200 but connected a number of Mitsubishi FX's this way to Kepserver.
Here is the manual and it shows the connection between two C200's so you should be able to work it out (Page 203).
http://scemosystems.fi/downloads/pd...ogrammable_controller_operation_manual_en.pdf
Hello, first off I am not a PLC programmer so bare with me.... We have specialized glass lathe that has a C200HS PLC system that has probably sat...
18
2,135
Saludos amigos. Tengo una impresora comexi modelo FS1500, la impresora usa intouch 7 en Windows 2000, viene con un PLC Omron C200HS, también usa...
1,094
Hello, New to this forum and to Omron. Really hoping someone has some input or advice that I haven't already tried. Have exhausted all I could...
1,395
Hi all, I have a few old Omron SYSMAC C200HS CPU01 PLC's and am trying to learn what is req'd in order to communicate with them. I have an...
2,338
Hi I am uploading from an Omron c200hs and I cannot retrieve any comments. We don't have an original program on hand to follow from with regard to...
1,745
