Omron C40K Instruction - MPRF
Abigail
May 2013
Jeddah
21
Hello Guys,
a pleasant day to you.
I have an Omron C40K plc unit, which is to be replaced with CP1E. On the program file, I came across an instruction, MPRF ( 61 ) where an equivalent instruction is CP1E is not available ( I am not sure of this! ). The instruction available in CP1E is IORF. Is the instruction IORF equal with MPRF?
I have attached the picture of the program ( syswin ), for reference.
Thanks for the assistance.
Leo
That is labelled group 2 high-density I/O refresh - no group 2 with the CP1 series. What do you have in actual I/O on the C40K?
The other thing you could do is download a C40K manual and have a look at the instruction.
I have the manual, Cat. No: W146-e1-5 ( C20K/C28K/C40K ). Looking in the instructions, I could not find the MPRF, only the IORF is available.
If you have another manual, wherein I could read the MPRF operation, could you share with me the catalog number?
Thanks.
The machine is a bag machine, or a vertical filling bag machine. It uses a film / wrapping material with a registration mark, to cut the pre-desired length of the bag. The machine can operate using the photocell mark detecting the registration mark, or using a shaft encoder.
On the instruction, the input bit is the selector switch for a registration mark or a continuous print ( encoder ).
Thanks gclshortt.
The input signal of the instruction MPRF, is for the selector switch for a continous print or using registration mark.
I'll look into this HDM, and what is the equivalent instruction in CP1E.
Cheers.
Leo
We are tasked with troubleshooting and repairing an Omron C40k-CDR-A PLC, we are looking for the correct software and a host link unit in order to...
2,338
I am trying to get info on an omron sysmac c40k. The plc works, but 2 of the inputs are shorted and i would like to just move the inputs to an...
1,975
Dear friends, Please help me to identify this part it is on a OMRON C40K PLC which is not going to RUN mode I found this part...
1,415
We've got the Omron Sysmac C40K in a few of our machines at work, one of them started to behave bad and gave up. Power LED on and input LEDs work...
9,855
I have Omron Sysmac C40k programmable controller... I want to program it but i dont have programed eprom and Host link unit.. But I have Syswin...
6,666
