Omron CPM1A PLC - Data Logging
fez
Aug 2004
I am using an Omron CPM1A PLC to control a quality control station. I am interested in logging the I/O ports in real time. I was told by the Omron rep that it is difficult to do this using this model of PLC because it doesn't support RS232. The only way to log data according to him was to use VB. Does anyone know how to do this? My programming skills in VB and syswin are weak, so the more detail that can be provided, the better. Thanks.
Not to sound like your vendor, but the next model up, CPM2a, is nearly identical in size (except the CPM1a has a 10pt I/O model and the smallest CPM2a has 20pts) and it comes with a RS232 built in. This might just save you a ton of time and trouble.
Just food for thought...
CPM1a, I/O points: 10,20,40,60
CPM2a, I/O points: 20,30,40,60 with RS232 port
the price is not too far off either
John
To connect to your PLC you need adapter (about $120) to RS232 .You can use MS access to collect data with the right driver.For VB application you will need this driver too.(DDE)
Anyone know how to connect rotary encoder to CPM1A? I've tried using PRV to read the value, but i can't read the value in the memory. I used PRV (0 0 DM100). My encoder is Omron E6B2-CWZ6C. help please
Thanks!
instructions Upload Program PLC Omron CPM1A to PC for people starting go to view instructions Upload Program PLC CPM1A please you selection a...
3,387
Hello, I am using syswin 3.4, and I am unable to send and receive sms using omron cpm1a PLC. My questions is, can anyone tell me or give me an...
3,878
Dear PLC Experts, I am doing modification in Omron CPM1A PLC program. This is oil dispensing machine, used flow meter (High Speed Pulses)&...
5,747
Im using Omron CPM1A plc. is there a build in clock that i can call everytime i need to log a certain incident? If not can someone send me a...
7,115
hi, when i try to download modified programm to cpm1 plc i got this message "UM is protected". the machine is used one and need make some...
4,742
