Buttons336
OP
I don't have the correct cable to connect to the RS232 Port on the PLC & I have a true RS232 Port on My CPU.
You said this in an earlier post, but now you are saying that you do not have the correct cable? If indeed you do not have the correct cable, then this is the first place to start.We Have the right cable but it will not recoginize the PLC After several Attemps.
gtsuport this is the ADI panel that needs to be complete by the 30th Buttons336 is working on it. so we appreciate any help you or anyone of the guys can give
Set up the driver for the correct com port. Set for Toolbus, auto detect and 115kB. Then use auto online and away you go.
-|x1|-------(y1) (orout)
-|x2|--------(y1) (orout)
-|x1|--------(y1) (OUT)
|x2|--
Also understand that the output will be updated to the status of the "last" state scanned in the program.
kboggs said:how can you use the output more than once. is this possible? automation direct uses an OROUT in order to use it more than once. I think we are having problems being able too (per buttons)
