Omron NS HMI used as a passthrough
Soggy Canuck
Jan 2008
Vancouver
229
I have a little project involving a pair of NS10 HMI's linked to a pair of CJ2 PLC's via ethernet. In addition I will have a CQM1H PLC hooked to Serial Poet A on each NS10. I have a pair of Mitsubishi FX series PLC's which I need data passed to the CJ2 PLC's. These are located in close proximity to the NS HMI's. My question is can I use the NS HMI's as passthrough devices using the second NS serial port?
Hello, and yes
From the 'Common Setting' tab, follow the 'Device Data Transfer Setting' option.
This is a 'fairly' recent addition if I remember correctly, so your screens may need their firmware updating to 8.2, and the NS projects converting accordingly. Instruction to updgrade screen is installed with CX-Designer, and converting a project is straightforward from within CX-Designer.
Pp
I'll have to check into upgrading my CX-Designer. The highest version of firmware shown in the listing is 8.0 for CX-Designer Ver.3.001. Thanks for the heads up.
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
289
I have an Omron CQM1H-CPU21 and a NS8-TV00B-V1, I have followed the manufacturer's spec on how to set this up and all I got is the HMI is trying...
886
Hey everyone, I'm new to this type of HMI and I have a couple of questions. 1) I'm creating a screen with text on it and base font is "DFNB-EN"...
422
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,211
Hi all, I have to say first that I have no experience with Omron devices, but here's the challenge that I'm facing. I have an Omron CP1H...
1,708
