Omron NT 20s Touch Screen
Gunner
Sep 2003
25
I am having trouble downloading to an NT 20S touch screen.
After I set the screen to transfer mode and start the download the following appears on the screen
Tool - PT transfer evaluating data
0 KB
and on the PC the following message appears
Transferring data
After a short time another message appears on th PC
PT has flash ROM memory ok to delete
After I press the enter key to continue the message on the screen disappears and the PC message appears
Transferring Data
After a short time The PC message comes up
unable to transfer data
There are no other error messages at all.
Does anyone have any ideas on what could possibly be wrong?
I have RTFM and searched various sites but have come up blank
any help would be very much appreciated
regards
Gunner
It's been a while, but I seem to remember that in this situation, you need to go through the screen menus and "Initialize memory". Downside, it erases whatever is in there, but on the upside, I've always been able to write to it afterwards.
Hope this helps!
Regards,
Jordan
Did you initialise all memory areas before attempting a download? There are several areas.
Problem still exists, I have read and re-read the manual.
I can't even upload from a good screen in service.
It has to be a problem with my software/ ancient laptop.
I think its time to give the Rep a call, I will let you know how I get on.
Thanks for the help so far.
Gunner
banghead
the last time i looked at an omron nt i had to set up the laptop's com port, something like 9600baud, even parity 2 stop bits. i also tried 3 cables we had here before getting the right one, they were all omron (don't have numbers handy, sorry). didn't have to initialise any memory on mine?
I have a unit that pre-dates me, and it shows a Kanji character where it should have a space. They are on *every* screen, including the system...
1,936
I have a machine with an Omron Sysmac CQM1 PLC & NT20S HMI. I got the NT software installed on a VM & the OEM files, it opens OK. I also have...
2,448
Good day to every body I am trying to replace old touché screen [omron nt20s-st121-v1] To new one [[omron nt20s-st121b-v3] they look identical and...
1,982
I have two of the same units that are using a CPM1A and an NT20S-ST121B-EV3. I am not able to connect to the touch screen as far as i can tell via...
3,999
Hi, I'm learning to program my plc with hmi nt20s ,do someone has a program example? many thanks, JuGa
1,367
