Omron Output Fault
Rashid786
Jun 2010
Islamabad
The plc output donot work sometime although condition is true. I have seen a difference in activation sign while in online mode as seen in the attachment. Please tell me the reason and solution.
Welcome to the forum.
here are my suggestions.
1. the output is used somewhere else in the program and the rung logic is false.
2. you are using a move statement to this output word turning the output off (not sure of Omron allows this)
I do know from personal experience with an S6 that if you program the output in two locations, the program can act funny.
james
PLC Output
Hello Sir,
Thanks for your time and support. Duplicate coil is not allowed and there is no duplication in the program but this output error appears. If someone has experienced such problem then please guide me.
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
115
I have a project to control the speed of motor DC using PWM Output on PLC and when im on working i have a several trouble and of of them is the...
222
Hi, I'm using CX Programmer and just seeing what the best way to trigger an output from the plc clock time would be. I need this to come on at 9am...
1,745
Hello Sir/Ma'am, Hope you and your family are safe in this Covin-19 Pandemic. One of my client have a machine in their ceramic industry which...
2,617
Hi, i already make a program CP1E with pulse train ouput (PLS2) to control stepper vexta. Can i use work online simulator in cx-programmer to see...
1,461
