fuzzywuzzy
This is a question for you OMRON guru's I want to use a timer to delay an output on state. When the timer times out the output should turn on causing the next step. In allen bradley timers and counters have a done bit address, and enabled bit address, and a timer timing or counter count bit address,,,, how does Omron work?? What would be the adddress to use on a normally open contact to make it close or turn on when the timer times out???
Harry
Harry
