Omron to HMI communication problem.
Jeffwiley
Oct 2020
Georgia
I have a Omron CP1L PLC that I'm having problems communicating with a NS5-SQ11B-V2 Omron HMI through ethernet . I have the exact same set up on other projection welders . After installing the HMI and PLC I copied the PLC program and HMI from a welder that is working and transferred it to the new welder but I have no communication from PLC to HMI.
Make sure your addressing/communication setup is correct. I'm not familiar with Omron PLC/HMI, but communication setup may be separate from the 'programs' that you copied, or what you copied may cause it to be looking for a connections at the IP address(es) of the original machine rather than the new one.
You will have to set the PLC to network 1 (the ethernet port) with CX-Integrator - that is not in the CX-Programmer settings.
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
289
We are currently upgrading one of our assembly machines which has an Omron CPM2A PLC with a C-more micro HMI but it will not communicate with the...
33
9,874
Hello friends, Can I seek your expert advise, I am new to Omron HMI/PT interfacing to Omron PLC. My question is how to communicate this to? 1...
3,676
hi we have omron C200 HG CPU 43. The problem is, it is not communicating with HMI while it is communicating with laptop on same port. Also its...
3,365
Hi.. I am new for Omron HMI, i want to communicate Omron HMI i.e NS8-TVo1B-V2 with Fanuc robot controller R30iA (i need to send some data from HMI...
4,242
