On CompactLogix PLC's, What is the SD Memory Card used for?
gbradley
Apr 2002
Corona, Ca.
1,637
CompactLogix PLC 1769-L30 ERM
Should I be saving the program file or Data there?
How do I do that?
The image is all grayed out in the Non Volatile Memory tab in RSLogix5000
I pulled the card out and restarted the PLC and everything still works the same.
1. The SD card allows you to save the program and all documentation and comments.
2. If you use automatic device configuration (I do not) then you can also store the firmware on the SD card and the processor will automatically flash the drive or whatever device you are using. This will only work with minor rev changes though so it is mainly just a compatibility feature.
3. You also can use the card for storage and retrieval of recipe data.
To store your program you must be online with the processor in program mode. You may then save to non volatile memory.
All in all #1 is extremely useful. #2 and #3 are useful but the implementation AB chose for those features is a pain and there are other methods I choose to use to suit myself and lower development time.
Hi everyone, i have a compact logic 1769-L18 PLC and I'm using FTalk View ME for the display. I wanted to do some visualization on Grafana. At...
96
Hello. Was just curious, if it is possible to load an image from an SD card on to a Compactlogix PLC that came straight out of the box brand new...
546
I'm working on troubleshooting a PLC for a piece of manufacturing equipment. The issue I'm trying to resolve is an open wire fault not getting...
532
Hi all, this is my first post and appreciate your advise in advance. I have a job to migrate a system form Mitsubishi FX5U to AB...
842
Hello Everyone, A very important question: We are having trouble receiving analog output cards (5069-OF4) for our CompactLogix PLC racks. I am...
3,195
