one shot generation in controllogix 1756-L61
olealf
Aug 2013
USA
Hi
I am new in ControlLogix, so I don't know the details of the scan cycle, I have been checking a couple of programs and I have found the following one shot generation logic (see the attached file)
I:060 is a sensor that goes low when a carton is detected.
From the comments of the logic I know that a one shot is generated, but not sure how is working under the scan rules for contrologix
Can someone explain the details ?
Welcome to the Forum !
Can you take a screen shot ? Text-based ladder is notorious for being hard to format on the Forum.
ControlLogix is very similar to SLC or PLC-5; it solves left-to-right and top-to-bottom.
On the routine scan when the Carton Detected sensor bit is first False, the top level of the rung is evaluated. Because B3[16].2 Shot Complete is not yet true, the B3[16].1 Start-Shot bit is set true.
On the same scan, the second level of the rung is evaluated. It sets the B3[16].2 Shot Complete bit true.
On the next scan, the Carton Detected sensor bit is still False, but now the B3[16].2 Shot Complete bit is true. That makes the Start-Shot bit false for this scan, and all subsequent scans until the Carton Detected sensor goes true then false again.
This is one way to do a One-Shot, but I prefer to use the built-in ONS instruction in the ControlLogix. It uses a single BOOL to store the state of the function, but it's obvious what it's doing when you see it onscreen.
A plug for FastStone Capture, my favorite screen-capture utility. I realize there are others, and SnagIt is a favorite, but this is the one I like best.
http://www.faststone.org/FSCaptureDetail.htm
I wholeheartedly second that plug - I've been using it for many years...
Earlier versions were "shareware", and the later versions need a purchase, but if you can get to try it out, it is well-worth the small cost.
One of the great features is that is a portable application, that doesn't have to be installed on the machine you run it on. This is handy for grabbing screenshots of SCADA nodes etc. Just plug your USB stick in with FSCapture on it, run the program .exe and capture away! No "install" needed, so you can leave the target machine "untouched".
attached pic took about a minute to make....
Hello all. This is a very lonnnnnnng shot but worth a try. I have an OMS Group Impact100 metering machine. At this customer it blows foam into 3d...
188
Howdy Everyone, So I have been retrofitting a cell to run different fixtures and updating it with new drives and a few other things. It runs...
1,505
Hi all, I am working on a ladder program in AS and I was to trigger a reading on my IO link sensor every .5 s, and use that value to run a...
542
Hello Everybody, Someone must be familiar with Horner Cscape, I wrote a program on a overhead door with a 3 button station,I'm working on a...
1,458
personally I don't care about golf - but this is one impressive shot ... if it weren't on tape, I wouldn't have believed it ... the first video in...
1,504
