Online with IMCS - Cable & Software?
ckchew666
Aug 2003
Malaysia
591
Does anyonere here has experience in IMCS?
I'd like to know what is the software & cable to program the IMCS 4100-214-R ser D
Hope someone can guide me on this.
Thanks.
The software is called GML Commander and you need a serial cable - can't remember if straight or crossover.
GML = Graphical Motion Language
Thx for ur info, the cable is like 1747-CP3 or 2711-NC13?
As I said, I can't remember if the cable is straight or crossover. I've looked for info but can't find any.
The NC13 might work.
I believe it uses XON/XOFF protocol so only TX, RX, and GND required.
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
60
Hi. I’m trying to upload program from existing PLC S7-1200. Create new project in TIA v15.1 then upload. After upload successfully, go online but...
233
Does anyone know of a way to detect if someone is online with the controller in ControlLogix (from logic) I'm thinking that maybe there is a CIP...
391
Got a VIPA 315-2AG23 that i try to go online with but can't seem to make it work through a network. I can go online if i'm plugged directly in the...
275
I'm getting the Dreaded "Failed to go Online with the Controller, Unable to Open Connection - All Connections may be in use" I suspect an...
488
