OPC configuration, PC to S7-300 PLC
userxyz
May 2002
any
2,768
I tried OPC, but I need help, doesn't work @ the moment.
In OPC scout I do not get my symbols of my projects.
this is my config:
Everything looks OK, except for the following:
In NetPro, for the PC280 you have to add a "connection".
Select the PC280 - OPC Server, and then click on the "spreadsheet" like list below the graphical layout, and a dialog for adding a connection will appear. Specify an "S7" type connection if you are in doubt. From then on it is fairly straightforward.
You can also follow my guide in the downloads section.
Visual Basic question
Ok, I have the data in OPC scout, so this means I'm ready to do something in VB.
I know S7, I have an OPC connection and I know VB, but how can I connect data...
Example:
Dim a as input
a = OPC_BOOL
If a = true then
shape1.backcolor = .... green in hex...
Else
shap1.backcolor = .... red in hex???
U can understand what I mean by this, something I want to be able to do...
Abou the connection, I tought, OLE, but the only thing I can find in the list is this: ???
Opc
OPC is driving me nuts, Now I can't connect to online PLC's anymore, even I delete everything in the Station Configurator on the PC, can't get online anymore, Siemens = troubles
I know
I now know a little step further how to connect data in VB
But how can I write something
Step further
And this is what I have tried to link the RAMP of my PLC to the text1.text object:
Private Sub DatCon1_ValueChanged(ByVal Count As Long, ByVal UserIDs As Variant, ByVal ItemIDs As Variant, ByVal Values As Variant, ByVal Qualities As Variant, ByVal TimeStamps As Variant)
weergave = RAMP
text1.Text = weergave
End Sub
Anyone can help who has experience with OPC ... ?
assignement doesn't work
I'm trying to assign something like the Siemens Manual tells metodo:
But, the SET butoon remains de-activated...
Any help from OPC and VB knowers ?
Use OPC scout to modify values or read the manuals from the OPC foundation. You must make groups and items.
Opc Scout
In OPC SCout I can read the values, so this is okay.
But I want to do something with it in VB
Hey there! I have a query regarding the configuration of the OPC data server in the ArchestrA Galaxy, I understand that when the data server does...
1,813
Hello, I have not configured a new OPC Link before & was needing some help please.We have TDS running that is polling Totalflow meters. I was...
1,341
Hello, We recently acquired a Siemens line and we have a station running the S7 opcdaserver. I want to test out the OPC->ODBC service from...
2,296
I've got an AB ML1400, and use the CPR9 SR2 release of RSLinx Classic to configure the DDE/OPC topic for the PLC. Although I have 16 inputs...
2,261
Hi All How can i associate items in the SLC 5/05 with OPC topic created in RsLinx Gateway. I have created a topic in Rslinx and point it to...
4,844
