OT : A "Lockdown" Puzzle
Yes you can, I have a spreadsheet open with it calculating the length of the tunnel for any other of the three parameters.
But we still need to know what breed the cat is!
And, is it walking towards the front of the train and causing more resistance as the Earth rotates, or to the back actually pushing it along?
Edit: Actually if the train is travelling exactly North or South the rotation of the Earth would not be a factor.
Dang, I had a source stating that a mile is 2400 strides, but now I find another saying it is 2241 strides.
I suppose it depends on whether you are your way to work, or on your way to a bar ...
It was a joke about imperial units not being a unit...
:confused:
3 minutes is only SI-conforming measure in your post...
It was a joke about imperial units not being a unit......
If NASA doesn't concern itself with converting metric to US for its Mars probes and other things (0.3 meters per second to 0.3 feet per second equates to over 3 times faster, or 1000 gallons of fuel but only put in 1000 liters so it runs out) then conversions must not be that important - the train is still moving, unless a NASA probe falls on it.
Schrödinger's New Cat:
If a cat gets on an AMTRACK (USA) train when is it considered dead? As soon as it gets on, when the train crashes or when the train was supposed to arrive somewhere?
Hi Can some one share any references for online sinamic training , either on skype or zoom or any other platform. It could be one to one...
1,218
Hi I am trying to do data acquisition on an existing system which has an S7 300 PLC connected to an HMI using ethernet. The problem is that I...
3,928
Hi I've inherited an IFIX 5.5 application. A picture is enabled every now and then. I beleive its being enabled by a tag that is read from a PLC...
430
I have 15 wires coming from a black box sensor. I can't open it to look within. I know that two of those fifteen wires will comprise the feedback...
17
7,706
Which wire would you cut, Red or green? Hint: You are color blind :yeah:
4,052
