OT : A "Lockdown" Puzzle
' (He stated the gear next to the one he had a problem with was going backwards) '
You're kidding!!
I have a cool program that will calculate the driving and driven gear to achieve a ratio. You need to specify a tolerance. I plan to improve it because often the gears have too many teeth to be practical. To fix this I need to factor the driven and driving gears. Some solutions may take 3 or more gears to achieve the correct ratio without the number of teeth on any gear being to large. I really need to put have a parameter to limit solutions. I need to add a parameter for if the final gear is turning the same direction as the initial gear. I also need to have a parameter that limits the number of teeth on a gear.
A while back drbitboy challenged me with finding solution to the size of a box by factoring. I had a python program already.
I think this is a more practical problem.
Hi Can some one share any references for online sinamic training , either on skype or zoom or any other platform. It could be one to one...
1,218
Hi I am trying to do data acquisition on an existing system which has an S7 300 PLC connected to an HMI using ethernet. The problem is that I...
3,928
Hi I've inherited an IFIX 5.5 application. A picture is enabled every now and then. I beleive its being enabled by a tag that is read from a PLC...
429
I have 15 wires coming from a black box sensor. I can't open it to look within. I know that two of those fifteen wires will comprise the feedback...
17
7,705
Which wire would you cut, Red or green? Hint: You are color blind :yeah:
4,052
