OT: Cable stripper/slitter recommendations
kolyur
Oct 2004
Wooster, Ohio
1,602
I am getting weary of using a utility knife to strip small multi-conductor cables (i.e. sensor cordsets). I've been looking at a few cable stripping tools--can anyone share their experiences? Do they work as advertised? It seems like it would be easy to nick the inner conductors if you're not careful. The two I am looking at are the Xcelite CJS100 and the Greenlee 1900.
I have used the Greenlee type for a few years. I normally set the depth with a scrap piece of cable before I cut the actual cable just because you can be too deep and nick the inner wires.
What I like about this type is you make the circular cut, then use a handle on the tool to rotate the cutter and then make the vertical cut. Even if you are not quite deep enough, you can generally pull enough to finish the split.
This is a bit off-topic in a strict PLC sense, but it is in the process measurement area. I need to strip some Alpha 9058C coax to mate with TE...
21
4,831
We have a kit from Allen Bradley for stripping/crimping ControlNet cables and someone has walked off with the stripper. Our supplier can't get the...
2,900
I am considering using a "magnetic cable tie mount" like this one: https://www.grainger.com/product/MAG-MATE-Magnet-with-Zip-Tie-Holder-49M018 It...
98
I have an existing machine that we are adding some functionality. Currently every cable such as a cable going out to a 4-20 psi sensor for example...
246
Hello everybody, I believe that I will find experts here who have already solved a similar topic. I need to calculate the length of the...
349
