It's not directly PLC related but it is probably a problem that some forum members have solved in the past.
The issue I have is that we are working two shifts to commission a new facility that has various sections of it locked out for various reasons: Utilities are run to the machine but need to be locked out while the commissioning process is on going for equipment that will use that utility. We can transfer employee locks during first to second shift change but there is no one is at the facility during third shift. We are basically doing a partial lock out of only the items we are doing maintenance on.
We have a lock box that initially had 24 locks in it as there are many subsystems that are being verified by a number of employees. Employees add one of these facility locks to whatever valve, disconnect, etc. where they will be working and then put their personal lock on the group lock box.
The last man to unlock on the late shift can then tag out the lock box with a 50# strength wire tie that is cut by first shift before they start to reapply their locks is the current method. Is there an acceptable / better way to install a lock with a key that that can be transferred to the first shift somehow?
