Panelbuilder 32 problem
POWER_PACKED
Apr 2004
48
HI - I have Panelbuilder 32 which I have been using for a while on windowsXP. Had a problem and I had to format my laptop. So I reinstalled Panelbuilder 32 and the installation went just fine. The software runs fine, I can upload and download from the actual panel, But whenever I try to open my old files, it just doesn't want to open up. the following message appears:
unable to load file. not a panelbuilder32 file or file is corrupt or disk space is low
I am 110% sure its a PB32 file as I had to upload it again from the actual panel, just to make sure that my file was not corrupted, and I do have the disk space.
I am running WindowsXP with a fairly new laptop. I had a similar problem when I was trying to reinstall Panelbuilder 1400e and I was able to fix that problem by installing a hot fix. I am going blank on what I should do to get this panelbuilder32 going. Its getting on my nerves :rolleyes: .
Any help will greatly be appreciated. Thank you in advance.
Regards,
The file in your Panelview was most likely created using a newer version of Panelbuilder than is on your laptop. IE your laptop has version 3.80 and it was created with version 3.81 (which is the newest version)
If you update your version of PB32 to V3.81 your problem should go away.
Hello, I've got a problem when converting my old PanelBuilder aplication to the new FTView ME plataform due to the need of replacing my PanelView...
2,295
I'm trying to download to a panelview 300 from panelbuilder 32. I have it connected and can see it in linx, but every time I go to download I get...
1,312
Good Morning. I have an application running on a panelview 1000 which was created using version 3.81. I am trying to open it using version 3.80...
2,269
I am supposed to write the tag which indicates the system date and time in Allen bradley's Panel Buider 600. The protocol is DF1 and the software...
2,220
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
286
