PanelMate touchscreen tag question
glennlee
Sep 2006
Florida
Good Morning! I am translating some Panelmate touchscreens to another brand. While most of the tags are straightforward, one type has me baffled.
It is for a numeric display:S:15 = 2819 * QMS, N7:17 + S:15= 2820 * QMS, N7:25
Some background. This touchscreen is using DH+ to communicate with both it's own master PLC ("furn", node 3) and a remote PLC called "QMS"( node 5). The Master PLC also exchanges data with the QMS PLC.
There is an additional PLC (also called "furn" node 4) 99.9% the same in code and function.
The "2819" and "2820" are baud-rate and Node address designations. The first "furn" PLC is 2819. The second "furn" PLC is 2820.
The touchscreen for furn (node 3) is not configured to communicate with the other furn (node 4)
I need someone to describe what the tag example above is doing so I can replicate the function in the new screen.
I have a backup plan in case I have stumped the experts out there.:geek:
Here's my interpretation.
The expressions "S:15=2819" and 'S:15 = 2820" will evaluate to either one or zero. So (S:15=2819)*QMS,N7:17 will evaluate to either zero or the value in QMS N7:17. Similarly (S:15=2820)*QMS,N7:25 will evaluate to either zero or the value in QMS N7:25. Thus the sum of the two will be one value or the other.
I have a used molding machine with an AAc robot for part retrieval. The robot powers up and I can move it around, but it gets random timeout...
2,183
I WAS WONDERING IF ANY OF YOU HAVE ANY EXPERIENCE REPLACING THE TOUCHSCREEN ON A CUTLER-HAMMER 1785T. I HAVE THE PARTS ON THE WAY VIA BIG BROWN...
6,008
R
i have acquired a new cutlerhammer panelmate power series 1500 but i can't find the software to program it. has anyone programmed one of these...
8,667
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
520
Does anyone know how I can view the configuration file of a Cutler Hammer *.pps file without the software? I need to see what IO is controlled by...
1,274
