panelview 300 (keypad) computer connection
valley_brent
Aug 2006
Nackawic ,NB
17
hi all.
i am trying to use a panelview 300 with keypad (i dont have the part number handy as im on my home computer at the moment).
when i plug the connection wire to the micrologix 1500, the comm light stays solid (as expected) and the fault keeps blinking since there is no program loaded.
i am trying to connect to the panelview with my laptop. there is a built in rs232 port that i plug my straight-through db9 rs232 cable into. I cannot see the panelview in RSLinx and the comm light on the panelview keeps blinking....
i have tried both the null-modem and straight-through...
any help would be appreciated.
rPraveenkum said:
You should use 1747-PIC/AIC driver in the RS linx software for communication with PV 300
so if i use that driver and the straight-through rs232 cable it will work?
i am going back up to site today (2 1/2 hour drive)
you should use straight-through Cable have the same Baud rare as in PV300
use the following driver in Rslinx IF it is DF1 version then Rs232 DF1 devices
If it is DH485 version then use 1747-PIC/AIC driver in Rs linx use straight-through Cable for both versions
Best of luck
Best of luck
Read attached first If you have a PV300 Micro
how can i get a value from the keypad on the panelview 300 to an RSLogix 5000? i have to make this work: on the panelview 300 i put the # of...
2,525
I am having pvc300 with me. I created my new program in ccw. The issue is that after clicking discover in ccw my hmi is not showing up there. Any...
151
merry christmas and happy new year i have a click c0-00dr-d and allen bradley 2711c-t3m. can the panelview talk to the click plc via modbus...
246
Is this the clock battery flat? Does anyone know how to remove the back of the PV 300 micro. Is it possible to replace this battery. AB says it's...
1,179
Hey Guys I am trying to figure out the correct cable to use to connect from my laptop to this Panelview using panelbuilder32. I was sure I had...
2,052
