panelview 300 micro
tonyginger19
Jun 2005
alabama
I have just purchased a panel view 300 micro to play with. I got the firmware downloaded in to it just fine. I try to communicate through the RSLINX software using RS232 DF1 and it tells me that there is an error in communicating with it under diagnose configuration but it shows up in the RSWHO part.
any ideas?
tony
Tony, I just did a job with the 300 Micro. Had a few problems at first getting it to communicate. o_O Trial and error finally got it to work once I directly connected to it. I'm using a MicroLogix 1500 and the CH 1 port to connect to the PanelView 300 Micro via a 2711-CBL-PM05 cable. :confused: Don't like this set-up cause when you make changes and download to PV, you have to disconnect from CH 1 and directly connect to Panelview from Laptop. Thought RSWho would see both the MicroLogix and the PanelView 300 Micro. (Maybe someone knows why? just haven't checked into it yet)👼 . All is working, believe, I saw a question about using time and date with this PV, I have it working, no problem...also the security. Any questions will be glad to help.🍺
Is this the clock battery flat? Does anyone know how to remove the back of the PV 300 micro. Is it possible to replace this battery. AB says it's...
1,159
I have an opportunity to get some more experience replacing an old Panelview 300 Micro. I'd like to hear any advice you have about it. I suspect...
3,298
I lost the manual for this machine built in 2003 and need to put it back together. I have the Micrologix 1200 and PanelView 300 Micro programs...
1,777
I am tying to download application software to a fresh out of the box PV 300 Micro. The first hitch is a prompt that I am running v4.1xx RSLinx...
1,146
I went on a service call yesterday for a Micrologix 1500. An output wasn't activating and they wanted to know what was hanging it up. It was a...
2,810
