Panelview 300
tcf24m
Aug 2004
Cambridge, Ontario
24
Hi
I am using the panelview 300 (2711-K3A10L)...I am trying to develop the HMI but I do not have a devicenet network to plug into, so i get a "comms error = 11" does anyone know how to clear this fault away so I can contiue to develope the HMI without plugging into a network.
Tom
If I understand correctly...
To "develop the HMI" you will use Panelbuilder32. You can develop the whole application without actually downloading it to, or even being connected to the Panelview. The Panelview should only be needed at runtime.
Ya, one of my gripes though about PV/PB, you MUST download to test your app.....though it does check for errors prior to the download....Just wish there was a runtime test in the software. Aside from that PV/PB is easy to use and gets the job done in most instances.
Greg
To verify a panelbuilder application without downloading it, just save it as a filename.pva file instead of a .pba file and it goes through the same verification as when you download the app.
Joe
Or even easier, on the menu click application > validate all
thanks for the replys...I was more of just trying to see what everything would look like when it was actually running of the 300...but i called are sales rep and he told me that you cannot get rid of the pop up window unless you solve the communication error...and since i don't have a devicenet up and running yet i am stuck with it(grrr).
Thomas Franklin
I am having pvc300 with me. I created my new program in ccw. The issue is that after clicking discover in ccw my hmi is not showing up there. Any...
148
merry christmas and happy new year i have a click c0-00dr-d and allen bradley 2711c-t3m. can the panelview talk to the click plc via modbus...
228
Is this the clock battery flat? Does anyone know how to remove the back of the PV 300 micro. Is it possible to replace this battery. AB says it's...
1,160
Hey Guys I am trying to figure out the correct cable to use to connect from my laptop to this Panelview using panelbuilder32. I was sure I had...
2,047
I need to utilize the program of Panelview 300 standard into Panelview 7 plus. Can anyone plzz help in this regard??
1,404
