PanelView 550 has different RAM capacity in diff version?
ckchew666
Aug 2003
Malaysia
591
We've a customer using PV550 version 2.0++, the limitation of File Size Limit is 114623Bytes. Currently, the project has already utilize 92959 Bytes. We need to add some screens into the current project, so the spare Bytes are not enough.
I've check using PanelBuilder32 that the PV550 version 4.0++ has File Size Limit of 245695 Bytes. If in that case, it's good enough for the project expansion.
Can you please verify this?
Attach is the print screen for PV550 Keypad hardware version 4.0++ and 2.0++.
Thanks.
You'd need to post the file in order to check it.
I'm fairly certain that a good memory saving technique would be to declare objects that appear on more than one screen as a global object.
Hi all, Im having trouble transferring a program from one panelview 550 to an new one. I can insert a flash card into the old panelview and upload...
20
348
Client has multiple spare Panelview 550 (2711-T5A10 L1 PV550 Touch Devicenet)...
688
need instruction on how to download an existing program to the PV. I am very new to PLC's they came with the job so now sink or swim don't want to...
909
Good afternoon I have a panelview 2711-k5a2 ser B Rev-C frn 1.07. Can this be up graded to Rev J frn 4.10-4.XX? Thanks
17
3,433
Panelview 2711-K5A8. Customer has 6 of these in service connected to SLC 504’s. One has a bad backlight and I need a solution to replace it...
2,257
