PanelView+ 600 Alarm Trigger Issues
stinger43211
Mar 2009
ohio
I am currently working with a slc5/03 and a panelview+600. I have everything working except triggering alarms to appear in the alarm screen. I have tried everything i can think of. the tag i have setup is analog and unsigned integer. I can read the string i am sending it through another screen i have created using a multistate indicator. Under the alarm setup i have is setup for the current tag, trigger type bit, label- alarm and under advanced i have current alarms display call the [alarm] screen. in that screen i even tried filtering with no luck! any help would be appreciated. thanks!!
I have less then 30 alarms and Dont believe my setup supports DINT since its a logix 5000 comand. i have even tried having it look at a single bit and that wont even display!
I have the following setup for a PVP400 to ML1100.
Trigger: {::[1344]N50:30,L2} [1344] is the device shortcut
Trigger type: Bit
Messages use trigger value 1-32
Make sure that Alarms are enabled in the startup
Make sure you have a screen with an Alarm banner
Post screen shots of your alarm setup, all three tabs.
First time using a panelview. I have all of my alarms mapped to bits of dints. How do I get the alarm panel to popup when an alarm happens...
2,125
The banner is completely unreadable. Is there a way to adjust the size that the alarm banner will display on FT ME 7.0 for application? Thanks...
2,393
I've got a couple of PanelView Plus 600 panels in the plant. I want to log alarms from them. I've got Kepware's OPC drivers and data logger...
3,055
I have converted an old PV550 to a panelview 600 and although the alarm screen comes up I cannot get it to display the tagged messages. Also for...
2,500
I am trying to go to a 504 CPU. and on my hmi I am getting a 9028 error. can someone explain what they mean by change reference?
225
