f16bmathis
So... Panelview 600 (2711-B6C9L1, SER B, REV K, FRN 4.21) I've turned off the printer port, has two ports, I've tried connecting to both using a cable I bought from the automation store. Cable is a USB to panel view cable USB-2711-NC13. Says it is a direct replacement.
USB port is 14 (also tried 2) used auto configure, tried manually at 19200. Never connects. I am supposed to see it in RSLinx right? Also, went into the panelviews comms and changed the NODES from a 2 to a 0, didn't work either.
I've also tried connecting using a USB adapter with a direct 9 pin din cable we have laying around.
Allen Bradley right!?
Thanks!
Thanks!
