PanelView Plus 600 Compact to ML 1400 Comms
PLBoudette
Jan 2006
Albany, NY
41
I'm trying to get communications working between a PanelView Plus 600 Compact unit and a MicroLogix 1400 PLC via Ethernet. They each use a standard Ethernet cable plugged in to an Ethernet switch. I've set up the PVP 600 Compact using FactoryTalk View Studio & RSLinx Enterprise with IP Address 192.168.137.2 with Subnet Mask 255.255.255.0. I've also configured the Runtime Target to point at the MicroLogix 1400 with IP Address 192.168.137.3 with the same Subnet Mask. When I run everything, it looks like the PVP 600 is polling the PLC for data, however, I don't see any activity lights on the PLC. Looking at the diagnostics for the PLC, it is receiving packets but is not transmitting. When I ping the PLC, the activity lights blink. Is there something more I'm missing with the communications? Do I need to set up MSG instructions to handle the comms? Thanks for the help.
Haaa
:ROFLMAO: Haaa That a problem.That a blunder mistake. Remember being a automation engineer you have first thing to do check all firmware and software compatible issue
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
475
Hello , I have an HMI of PV+ 600 (2711-T6M5D) Ser A Rev B, This HMI doesn't have the ethernet port i have to take backup through communicate...
662
Hello all, I copied the MER file from one PanelView Plus 600 to another one, using a USB drive. On the new HMI, I copied the MER file to the...
634
Hi all, I have an old PanelView Plus 600 (2711PC-T6C20D8) that I am repurposing on our site - I have flashed the firmware to ME version...
987
Hello Team, I have a question, I have been working with a panelview plus 600. But I have deleted all the .mer directly from the HMI, after that I...
1,711
