PanelView Plus 1500 Alarm Banner
JamesWSY
Jul 2005
Jakarta
81
Hi..
I used Panelview Plus 1500 with DH+ to PLC-5/25 and set alarm triggered using bit type, 4 word, tag on RSView Studio is
::[PVP]B15:0,L4
Tag type analog with integer format, minimum tag is -32768 and maximum 32767.
I have a problem with no alarm banner displayed, no alarm list when an alarm triggered, no error message on PV+.
How to solve above problem? Any idea?
Thank you.
James
There seems to be a mismatch between the tag type selected and the tag you are using for alarms.
If the tag you are monitoring is a bit (or array), but the alarm trigger is set for value, I don't believe your alarm will trigger.
I suggest trying to set the alarm trigger to bit, as a starting point...
Rick
121
Hi there, Maybe I am overthinking this issue, but here is what I have going on. I have a program running for a water valve on a DI system. We...
463
Hi guys. Currently working on a project that requires a Panelview Plus 1500 to read a CSV File (recipe) from a network drive. The issue I have...
1,065
Hi, guys, how’s going? I added one “Trend Object” on screen A in PanelView Plus 1500. Then configured “Refresh Rate”, “Buffer” ……and set up...
1,930
Good morning, I am onsite at a customer. They have a panel view plus 1500 that does not light up. The screen is always black. I am not very...
5,607
