That icon appears when the touch screen is intentionally disabled to prevent you from making an unsafe selection on the screen.
It can appear when coming out of screen saver mode, when you have repeatedly touched the panel too quickly, or if the backlight has failed or is in the process of failing.
If power cycling the terminal does not clear this fault, the terminal must be remanufactured or replaced.
