aamirawan91
My Panelview plus 700 HMI stopped working and I replaced it with a new one. Moved the sd card from the previously installed panel to this one and loaded the application/program and pressed "run application" and it did but after power cycling the panel the application did not start automatically. Instead it went back to the configuration mode where you have the options of "Load Application", "Run Application", "Application Settings" under "Current Application" bar. Current application box was empty and it showed nothing. Run application and application option settings were greyed out. I went into the load application option and there it showed the program in the internal memory and also on the sd card (external memory). I loaded the application/program again from the internal memory to the panel itself and went back to the same screen i talked about earlier but this time it showed an application in the current application box and also the run application etc options were now available. I tapped run application and it ran normally. But I have to do this same process every time I power cycle the panel. I think the application gets lost or something after power cycle but if that was the case it shouldn't show any application in the internal storage where you choose "source" to copy from. Applications and runtime in the other machines start running automatically once the boot screen is loaded. Also there is some kind of a startup option where you can select what should be booted first and mine have configuration mode selected and "run application" is greyed out there as well. What am i missing here?
