Panelview plus communication
srv
Aug 2010
QATAR
109
hi,
i have a problem with panelview plus communication with slc 5/05.I connected my PV+ through a switch to SLC 5/05.I got communication with PV+ and SLC5/05.But when i connected PV+ to SLC 5/05 direct it is not communicating.anybody please give me a advice.
With a switch you would use a patch cord ( straight thru cable).
With a direct connect you would use a cross-over cable. Are you ?
Hi there! I got a HMI terminal Panelview Plus 7 (PN-332439 / CAT 2711P-T12W21D8S) which work on a APP 8.00 i'm trying to modify with my FT View...
700
I have a CompactLogix 5069-L320ER (has 2 comm ports) I have a Panelview Plus 7, Do I have to install a Ethernet switch? Can I connect directly...
1,136
Good afternoon, I'm having some HMI communication issues with FactoryTalk View ME. I'm trying to make an update to an existing program that has...
2,565
Hi, We have around 10 PV Plus HMI connected to CLX via ethernet IP-CAT6 cable it was working in good condition for few years but now there is...
1,749
Hello, I am currently installing a PLC control panel and due to space constraints, we will need to install the Panelview 600 HMI separate...
3,386
