Panelview Plus runtime security
Terrep
Nov 2007
Sydney
38
I have made a page and configured the security code as 'B'. I have added an 'ENGINEER' account under the ME Runtime 3.20 and earlier tab. Yet when I log in as an ENGINEER a pop up appears with the following message 'Login of user 'ENGINEER' failed. Insufficient access rights.
Are you actually running a version 3.2 project ? I don't know if you can use the old-style security settings on a modern runtime project.
I always create an ordinary FactoryTalk User, then add that user to the 4.0 and Later Runtime Security user list and give it assigned class codes (A, B, C, D, etc).
FactoryTalk Users and Windows-Linked Users are created in the FactoryTalk Local Directory.
The easiest way to do this in FactoryTalk View Studio is to navigate down the project tree to the bottom, and click on the System folder, then Users and Groups, then Users.
Right-click on the Users folder to add a new FactoryTalk User.
Once you're using FactoryTalk Users, you need to pay more attention to managing the FactoryTalk Local Directory. If you end up Restoring a project archive and over-writing your Local Directory, you'll end up corrupting all of your User accounts.
I can't seem to avoid this, so I make a point of writing down all the Users and Passwords for each project so I can easily re-create them later if I mess up.
Hi there! I got a HMI terminal Panelview Plus 7 (PN-332439 / CAT 2711P-T12W21D8S) which work on a APP 8.00 i'm trying to modify with my FT View...
714
Good Evening , I added a few screens to a FactoryTalk View ME Application, I'm going to download this modified application to the same...
2,569
Good Morning , I have 2 FactoryTalk View applications and Runtimes that were developed for a Panelview Plus 6. I am replacing these...
3,686
Good Afternoon , I have a Panelview Plus 7 Performance HMI. I made some screen changes and created another runtime. I downloaded to the...
2,495
Hello, I am a fairly new integrator and have used this site to answer many questions that I have had and appreciate the help so far. I cannot...
2,750
