Yes if it has a serial port ( real one build in ) There are operating system restrictions also when trying to use the 1747-PIC/AIC+ driver. What OS do you have?
I have a question. Why I used two button left and right on PV300 micro but I cannot into configuration mode of PV300?AND it appears error 612 not network node...
See picture below for the proper cable. Also your PV needs a different nodes address then your ML1000. The default address for your PV is "2" but could have been changed.
You might try something different in the ML1000 3,4,or 5.
No,because in the time I'm busy but I will try again in the future. I used converter as the attach file but I cannot connect. Can I use this converter? or PV300 micro required to use 1747-UIC if I used USB port?
