Panelview300 micro to PC
Thanks Mickey
What is a real serial port? It is mean: I can use a PC(desktop) to download program?
See link below
http://www.google.com/#sclient=psy&...or.r_gc.r_pw.&fp=c778ced03085ee5&pf=p&pdl=300
It is mean: I can use a PC(desktop) to download program.
Yes if it has a serial port ( real one build in ) There are operating system restrictions also when trying to use the 1747-PIC/AIC+ driver. What OS do you have?
I have a question. Why I used two button left and right on PV300 micro but I cannot into configuration mode of PV300?AND it appears error 612 not network node...
See PDF ans picture below.
Again can you tell us what PLC the PV is connected to?
Can you post the PV's program also the PLC's program? ( zip them first)
  • configscreen.pdf
See picture below for the proper cable. Also your PV needs a different nodes address then your ML1000. The default address for your PV is "2" but could have been changed.
You might try something different in the ML1000 3,4,or 5.
PV300 micro
No,because in the time I'm busy but I will try again in the future. I used converter as the attach file but I cannot connect. Can I use this converter? or PV300 micro required to use 1747-UIC if I used USB port?
No, that apears to be a USB to serial adapter. The 1747-UIC is a USB to DH485 converter, you need it because your PV supports DH485 protocol.
You can change the protocol of your PV see PDF below.
Hi, I have a Panelview300 micro and not able to get to the configuration menu. Since the left and right button was programmed as function key...
4,186
iam new at this, so be nice,,,lol can anyone tell me if the 300 micro can control a timer, and can it change the a fifu outpout bit and if so how...
3,883
Hi all, I have Panelview300 Micro that connect to Micrologix1000. The machine is still running but the panelview give a message 686"Panelview...
2,854
I am new to PanelViews! Is there any reason not to change a counter preset directly from the panelview? There is not much info in the help file...
2,977
Hi, I am trying to communicate Panel view 300 with Micrologix1500 LRP. PLC: Allen Bradley Micrologix1500 LRP HMI: Panel view 300 CAT#...
1,998
