Parametre assignment error
Oct 2014
Singapore
Hi
I am using CPU 317-2DP..Its a Software Redundancy..
One of the Station(PLC1) is working properly,But Station B(PLC2) is in STOP Mode...I Cant able to put it in Start mode..
I have attached my Diagonistic buffer..Its very urgent
Diagnostic buffer of module CPU 318-2
Order No./ Description Component Version
6ES7 318-2AJ00-0AB0 Hardware 3
- - - Firmware V 1.2.1
Rack: 0
Slot: 2
Event 1 of 100: Event ID 16# 5371
Distributed I/Os: End of the synchronization with a DP master/IO controller on slot 2
Number of distributed stations: 2
Priority class: 22
Incoming event
02:12:56.662 PM 01/31/2004
(Coding: 16# 5371 1602 0050 0002 0000 0000)
Event 2 of 100: Event ID 16# 530D
New startup information in STOP mode
Startup prevented by:
Loading user program or internal inconsistency detected
(SDBs less than 200 incomplete, superfluous, or incorrect)
User program invalid
- STOP request exists
- Cold restart or warm restart necessary
Startup information:
- Time for time stamp at the last backed up power on
- Single processor operation
Current/last startup type:
- Automatic warm restart after backed up power on
Permissibility of certain startup types:
- Manual startup not permitted, corrections in parameter assignment, submodule, etc. necessary
Last valid operation or setting of automatic startup type at power on:
- No startup type/following memory reset
Operating mode: STOP (internal)
Incoming event
02:12:54.425 PM 01/31/2004
(Coding: 16# 530D FF04 C777 0341 0810 0100)
Event 3 of 100: Event ID 16# 49A0
STOP caused by parameter assignment error or unpermissible difference between preset and actual configuration: startup disabled
No relevance for user (SDB no.): 1007
Previous operating mode: STOP (internal)
Requested operating mode: STOP (internal)
External error, Incoming event
02:10:05.011 PM 01/31/2004
(Coding: 16# 49A0 FF44 007B 03EF 2A02 0B00)
Event 4 of 100: Event ID 16# 6547
Parameter assignment error assigning parameters to modules (not on P bus, cancel download)
no relevance for user: SDB number: 1007
Internal error, Incoming event
02:10:04.999 PM 01/31/2004
(Coding: 16# 6547 FF04 007B 03EF 0000 0000)
Event 5 of 100: Event ID 16# 5371
Priority class: 22
Incoming event
02:09:57.359 PM 01/31/2004
Event 6 of 100: Event ID 16# 4303
STOP caused by stop switch being activated
Incoming event
02:09:55.005 PM 01/31/2004
(Coding: 16# 4303 FF44 0000 0000 0000 0000)
Event 7 of 100: Event ID 16# 4300
Power on backed up
Initialization information: Initialization after power on (backed up CPU)
Previous operating mode: No voltage
Requested operating mode: STOP (own initialization)
Incoming event
02:09:47.384 PM 01/31/2004
(Coding: 16# 4300 FFF3 CE00 0000 0001 0000)
Event 8 of 100: Event ID 16# 494E
Power failure
Requested operating mode: No voltage
02:09:41.366 PM 01/31/2004
(Coding: 16# 494E FF4F 0000 0000 0000 0000)
Event 9 of 100: Event ID 16# 49A0
02:02:28.438 PM 01/31/2004
I don't have much experience with the software redundancy, but it looks like something in the HW configuration doesn't match what is physically there.
"STOP caused by parameter assignment error or unpermissible difference between preset and actual configuration: startup disabled"
Hello, I am programming a schneider modicon M221 in machine expert basic. I am trying to calculate a value and then assign it to another memory...
1,383
Hello, I'm not sure if this kind of troubleshooting post is allowed here, but I'm at a loss. I'm trying to configure a Grundfoss CIM 500...
1,770
Hello TwinCAT and CODESYS experts: kolyur, AustralIan, busarider29, et. al. I will be once again very glad to get your expert advice on this one...
2,059
Hi All Could anyone please explain to me why TIA didn't fill the right field by known MAC? As I understand from various videos and tutorials it...
1,772
I want to add a new ANALOGUE INPUT module into our PLC (Q68AD-G), but I'm a bit confused about something. I would've thought that the IO...
30
18,580
