part present detection? what sensor??
smcmanus
Jan 2006
Vancouver
109
Hi. I need to come up with an application for detecting a very tiny metal nut on a part. The part is at a distance of 200mm and is 1 cm in diameter. I have been using a Balluff a PhotoElectric Sensor http://www.balluff.ca/Balluff/us/ProductsChannel/Product+Detail/en/ProductDetail.htm?ProductID=BOS+26K-PA-1LHC-S4-C&ProductGroupGuid={8BF459B2-B1E0-4064-8C67-6F14F05FFD2E}&ProductGroupName=Photoelectric%20Sensors
but I find the Laser light beam is too spread. I tried the SICK http://www.mysick.com/eCat.aspx?go=DataSheet&Cat=Row&At=Fa&Cult=English&Category=Produktfinder&ProductID=7010
and it seems to work perfect(small light beam) but they cost $450 each. Does anyone know of a Type a sensor that may work in place of the SICK?
We use to demo an Aromat (Matsushita) fiber optic sensor that would count the columns on the Lincoln Memorial on a penny. The sensitivity could be set so that it would do this reliably. So I would look for this type of sensor which should be available from several manufacturers including Keyence, Sunx, etc.. I have also had good results with Keyence sensors.
I second (or third) the Keyence suggestion. They will let you borrow a sensor for 15 days to test your application. They have a complete line of fiber optic sensor cables and heads to match a wide variety of environments and there controllers are easy to setup and use. With that said, they can be a bit costly.
You may also want to look at IFM Efector. They compete with Keyence very well in these types of application and can be a bit more cost effective.
I would suggest looking into the Banner QS18 laser series:
http://info.bannersalesforce.com/xpedio/groups/public/documents/literature/66981.pdf
We use these all over and they work great for us. Being able to see that little red dot really helps with the setup. The cutoff point is adjustable via a small screw (personally I prefer that over the "teach" mode that some other sensors have). You'd need the Class 2 laser which has a 250mm range. The literature claims a 1mm spot size. Pricewise, I think you're looking at $150-200.
I have a 24v prox with three wires. I do not have COM available for 24v+. Can I just use the 24v+ & GND to power the sensor? It's not a critical...
19
4,835
Hello, I am still new to PLC programming and I just got this job two year out of school so I don’t remember much. I was given a task were I have...
188
Good morning crew! Ok my logic works but I am missing something. When the start button is pushed it should like the red light for 4sec then shut...
459
Hello: I need to buy one end-cap which was not provided by an ex-Rockwell distributor here. Since I do not know the part number I can't find it...
24
6,556
For a thermoset molder I am looking for a vision system that can monitor part removal from a mold. The mold temps can range anywhere from 300 to...
1,669
