Peripherial I/O Step 7, indirect adressing ?
userxyz
May 2002
any
2,768
What I need is:
I'm writing a function. At the outside of the block I just want the parameter P_OFFSET_BYTE.
PIB256
PIB257
PIB258
These adresses are the ones that I wanna read.
So, on the P_OFFSET_BYTE parameter I will enter 256 (INT).
The rest has to be done in the function.
But how can I call PIB256, PIB257, etc... when I only have an integer offsetbyte ?
Here's an example FC
Code:
FUNCTION FC 1 : VOID
TITLE =
VERSION : 0.1
VAR_INPUT
  iOffset : INT ;
END_VAR
VAR_TEMP
  abBytes : ARRAY  [1 .. 11 ] OF BYTE ;
  iLoopCount : INT ;
END_VAR
BEGIN
NETWORK
TITLE =for i=1 to 11 abBytes[i]=PIB[iOffset+i]
	  LAR1  P#P  0.0;
	  L	 #iOffset;
	  SLD   3;
	  +AR1  ;
	  LAR2  P##abBytes;
	  L	 11;
Loop: T	 #iLoopCount;
	  L	 B [AR1,P#0.0];
	  T	 B [AR2,P#0.0];
	  +AR1  P#1.0;
	  +AR2  P#1.0;
	  L	 #iLoopCount;
	  LOOP  Loop;
END_FUNCTION
Hi
The SCL version that I see in the title is a little more understandable:
for i=1 to 11 abBytes=PIB[iOffset+i]
I think I'll use SCL to do the job.
About your code, can you explain it a little please ?
Code:
TITLE =
VERSION : 0.1
VAR_INPUT
iOffset : INT ;
END_VAR
VAR_TEMP
iLoopCount : INT ;
END_VAR
BEGIN
NETWORK
	 LAR1 P#P 0.0;
	 L	 #iOffset;
	 SLD 3;
	 +AR1 ;
	 LAR2 P##abBytes;
	 L	 11;
	 L	 B [AR1,P#0.0];
	 T	 B [AR2,P#0.0];
	 +AR1 P#1.0;
	 +AR2 P#1.0;
	 L	 #iLoopCount;
	 LOOP Loop;
END_FUNCTION
I am having a step7 v5.4 program where the blocks are encrypted and locked. And the manufacturer is stopped the support. Is there any ways to...
181
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
253
HI! HOW COULD I OBTAIN THE NAMES OF THE STEPS OF A ROUTINE IN SFC LANGUAGE IN STUDIO5000? Or is there a system variable that gives me those...
343
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
557
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
690
