Photo Eye- PLC Integration
iahiii_2005
Jun 2008
Oslo
Hi All,
I am trying to achieve the following.
Basically there is photo eye that senses if the bag is present or not.
I have to use the photo eye's input to calculate a rate i,e bags/min and compare that to ideal rate and set a bit.
How would i go about doing that? I am trying to do this in SLC(RSLogix 500),any help would be greatly appreciated.
Also i am trying to calulate downtime like this "
" Once the photo eye does not sense a consecutive bag pass for a designated minimum duration, line downtime will start to be measured and stop when a bag once again passes on the conveyor.
" Downtime measured will be cumulative for all BTs run on the line for the entire production day"
Thanks and i really appreciate it.
Greetings, and welcome to the forum.
Here, this should give you some ideas to get you started.
Another useful instruction for your task is the retentive timer, RTO.
iahiii_2005 said:
Hi All,
You have your logic right there. Its similar to what was just laid out. But lets think about.
So, that is
if photoeye is not made then start photo eye delay timer
which is (in AB speak)
xio photo_eye ton
So this is,
If photo eye delay timer is done then start downtime accum. timer.
which is xic photo_eye/dn (this is the done bit) rto downtime_accum
Does that help? Thats the great thing about logic. Your english is half way to your code.
matt
Good Evening, I am working on a warehouse loading dock setup with 60 docks, trying to do trailer detection with display as to which docks are...
672
Hello, I work for a beverage company that uses a laser coder to print date codes on bottles. We have a problem where occasionally the photo-eye...
2,541
I am presently in Russia, and need to quickly aquire diffuse laser photo eyes from Germany. We used Sick laser eyes in this application at our...
3,548
Wow today i am having a big problem and felling pretty dumb! I am trying to use a banner vs1 photoeye as an imput into my slc 500. You can wire it...
3,145
can some one tell me where to find a photo eye that can see different color surfaces. I have a blue interlox belt that carries purple, green, red...
3,951
