Photo Identification and PLC's
_Gregory
Jul 2015
Wenatchee
Hello all,
I am in search of a method of using photo identification to identify different types of anode blocks. Once identified this equipment will need to communicate with a PLC to sort the anode blocks. The PLC will be a ControlLogix. The next step will be photo identification of any discoloration, cracks or spalling. Once again the equipment will communicate with the ControlLogix. Any advice would be greatly appreciated. I am in the dark and new to the Photo Identification field.
Regards,
-Greg
Rockwell has an Encompass Partner that does that exact thing, I just saw them at an RAOTM show. It directly interfaces with Logix platforms. Naturally, I can't for the life of me remember the name, but I'll find it for you.
Cognex is the 800-pound gorilla of the machine vision industry, and they do some very good integration with ControlLogix. They are Rockwell's principal partner for machine vision applications.
Keyence and Matrox both also make some devices that integrate well with ControlLogix.
Machine vision for automated inspection can be pretty specialized; I've done some extremely simple pattern matching systems, but for complex stuff I bring in a consultant. My guy is in the Seattle area, so PM me if you'd like his contact info.
D'oh!
I totally misread the original post....šŸ™ƒšŸ™ƒ
Read the title and jumped to a conclusion, then when I read the actual post, my brain skipped over the actual details I guess. :sick:
Hello all,
Regards,
-Greg
Wen you get a proposal, keep in mind that any vision system like you describe is going to be 80% lighting, 10% lensing/resolution the rest is software and development. If the proposal does not show close to this be suspicious.
Good Evening, I am working on a warehouse loading dock setup with 60 docks, trying to do trailer detection with display as to which docks are...
681
The following is a set of photos illustrating ESD damage to a circuit board. I got this from here...
1,681
Hello, I work for a beverage company that uses a laser coder to print date codes on bottles. We have a problem where occasionally the photo-eye...
2,552
We have a muting light curtain setup like the picture I am attaching here. However, a pallet sometimes hits the photo eyes (MS1 & MS2 in the...
26
9,016
hey guy , I'd really appreciate the help on this. so I have a photo sensor ( hanyoung pu-30 ) and it's rightly connected but the signal wire when...
2,133
