PLC-2 ICOM AI Software
rywins
Feb 2013
Philadelphia
29
We have a client with a PLC-2 that crapped out today (upgrading to 1756 in 1 month). We want to try and re-download the program to it but do not have PLC-2 software. We have an old license for ICOM AI software on a floppy disk that was purchased in the 90s...so technically we have a license. Is there any way to download an unactivated version online for free and transfer the license to a host machine (VM running XP/win98)?
The only reliable PLC-2 software link I have seen online, which would be for purchase, is the TOPDOC for PLC-2.
rywins,
AB has not supported PLC2's for years.
I would get in touch with the local distributor and explain to him what you are doing. He very may well have a system with the software on it that you can borrow.
regards,
james
Why not just get online with a T-3 terminal, and spool the program listing out to a printer or over the serial link (on the T-3) to a terminal emulator program?
I did this about a year ago, and it worked just as good then, as it did in the 80's.
Regarding ICOM... know about APS?
As I type... my laptop is trying to install APS V5.11 It gets all the way to disk 2 of 3 to the file : WHOIOFI.EXE and has been going for near an hour. Just wonder if anyone else remembers any quirks with the software install. I'm using XP but I added the memory cache statements in system.ini as per a search I did. This got me past one point on disk 2 of 3 which said I ran out of memory.
Just Curious if any one knows...
I haven't even seen a T-3 in over 15 years and that one was bad. and even longer since I have seen an AB program storage Tape deck
I think he wants to reload a backup program the T-3 could not store the program you had to upload to a tape deck.
Are the files "config.sys, msdos.sys, io.sys, and autoexec.bat" in the c:\ root directory (folder)? You might also have to try a DOS boot disk with those files already on it. The config.sys has the following two lines "Buffers =20" and "Files =20". The msdos.sys file as well as the io.sys file are blank files.
We are using some old DOS software with an AB SLC-500 plc. The software enables us to upload/download the programme, but we don't see how we can...
25
5,201
We're upgrading an old PLC-2 system programmed in ICOM. We have the files, the PLC logic is in a .LAD format. Does anyone have working...
432
Hi guys, Quick disclaimer--I'm a major PLC newbie. :) I'm trying to get a Windows PC to talk to an A-B ControlLogix 5561 PLC over...
3,320
Hi all.... My company want to upgrade PLC and HMI my injection machine(GoldStar IDE 350EN)using PLC LG Hicom 300,but i don't know anything...
2,845
Hi, I am using a S7 315-2DP CPU to connect a Woodhead Applicom PCI-1500 Series Card via a Profibus network. Has anyone used this...
6,613
