plc control heater treater
bhadana
Jan 2004
hello all,
here i have a problem . i have a heater treater for seperating oil and water .i have to make it plc control so please give me details about it how can it be done
bye
Interface Level Control
The solution to your problem is more process related. Though you have given little specifics, the application is like oil and water separator units used in the oil industry.
Water is heavier than oil and they dont mix. Therefore water settles below and you would need to employ interface level measurement. The vessel usually horizontal has a divider or separator inside to create two chambers. The oil & water is fed in one chamber. The level of the water or (interface between the oil & water)is maintained just below the height of this separator so all the oil overflows to the adjoining chamber and gets separated. Control of the water level is by continously draining the water based on the interface level. In your specific example this control maybe done by evaporating the water by application of heat instead of draining
Hardware requirements (1) Interface level transmitter, (2) PLC controller with at lease 1 analog input (level) and 1 analog output (water control valve) and (3) water control valve. You would need a higher-end PLC because this is a process control application requiring PID functionality.
I may be oversimplifying the theory and hardware but I hope this would give you a headstart. Please refer to the Instrument Society of America (ISA) website (www.isa.org) for info on instrument and other hardware sources.
Hello, everyone. I've been trying to wrap my brain around this for a few hours now - doing all the research. I am looking to control a heater...
28
25,105
Hi guys. I'm working on a logic to control multistage electric heater for an air stream. The heater consist of 10 sections with ON/OFF control...
2,414
Hi, I'm thinking about using commands for Melservo J5 controller via HMI without PLC. Have you guys done this kind of control configuration for...
163
Hi, I have a 1500 that controls a station with diferents warehouses, but i also have a 1200 that controls one of those warehouses, i have been...
293
Good day Forum Members I got a older Lincoln welder and hoping to make it work at our shop. Welder in question is the Lincoln Power Wave 455M...
224
